Disables the specified account locally.
| all | Specifies that all accounts, or all accounts of a certain type, will be disable. |
| admin | Specifies that all administrative accounts will be disabled locally. |
| user | Specifies that all user accounts, including Lawful-Intercept accounts, will be disabled locally. |
| name | Specifies the name of the account that will be disabled locally. |
Enabled.
If the user is disabled locally, the user's login will fail.
If you disable all administrative accounts, you can use the failsafe account.
The following example disables all user accounts.
disable account all user
This command was first available in ExtremeXOS 15.7.1.
